w220 Srs
I'm new in this forum and hope someone could help me with my Srs problem.
I have scanned the car and the front seats does not show operated when seatbelts is attached 😅 have cleaned all the plugs and also measured ohm , driver seatbelt plug measured 0,9 ohm closed and infinite ohm open. does someone know the correct ohm resistance for the belts , are thinking on building an emulator with resistor as a tool to check if problem solves before buying new belts. The coding for all systems in Srs is ok and also the voltage .
Many thanks for help .
Hans
