Stereo/command unit won’t turn on.
Old Oct 27, 2020 | 11:49 PM
Justin Jones's Avatar
2000 S430
Hi all! New the the MB world here, finally getting into my trunk of my 2000 S430 to find out what is going on with my stereo. Everything worked fine aside from no sound. Watched a couple videos of same same issues, mine was CD changer was very badly water damaged. Everything else was clear. Tried the fiber optic method of deleting the loop to the changer and directing it back to the amp. Now my head unit won’t even turn on. Any ideas? Thanks in advance!
Old Oct 29, 2020 | 10:12 PM
brooktre's Avatar
W220, R170, XU70
Does the head unit power on and then shut down, or is it completely dead? If it turns on and then shuts down I would suspect a break in the fiber or another component that is not powering on. If is dead have you checked fuses?
Old Oct 30, 2020 | 08:31 AM
2000 S430
It’s completely dead. I changed the fuse to the amp, though I should probably just go through and check them all. Cause the clock in the cluster isn’t working either and for whatever reason my keyless entry stopped working as well.
Old Oct 30, 2020 | 09:42 AM
brooktre's Avatar
W220, R170, XU70
Yes, you need to start checking fuses to get power to your head unit. Did the keyless and clock issues began after you disconnected the CD changer?
Old Oct 31, 2020 | 07:57 PM
2000 S430
Yea, I just got the car and was going through cause the keyless wasn’t working when I got it as well as the sound through the speakers, the door lock button on the dash, soft close, and head unit and dash clock were working though. I changed All the fused I had spares for. Everything worked fine aside from no sound. Pulled the amp and everything out, spliced it, and changed the fuse and now it’s dead.
Old Nov 1, 2020 | 09:07 PM
brooktre's Avatar
W220, R170, XU70
You can find many issues with the stereo using a volt meter and some general knowledge of the system. For the keyless go and the door lock issues, you really need to have codes read. Most recommend the Mercedes Star Diagnosis System (a Chinese clone of this) or another advanced code reader. Even some issues with the stereo need a code reader to correct. For a do it yourself owner, a code reader is a must or you will go broke paying for service or throwing parts at problems.
if your head unit turned on before you disconnected the CD player, I would retrace those steps and see if you can find out what happened. There is a site W220.ee that has several fuse charts for your car that may help and there is also a lot of other good info on that site.
Old Nov 20, 2023 | 03:34 PM
JakubT's Avatar
mercedes benz w220 s500
Hi, did you solve this issue ? because i got exactly same problem. Thx
