My s500 wont go into gear...has this happened to anyone??
Has this been a problem for anyone or is there a known history of this problem with this model??? Any info will be greatly appreciated
Thanks,
Valerie
Also...make sure your foot is FIRMLY on the brake and the parking brake is engaged. I have had it happen a few times and it seemed to go away when I changed the FOB battery.
I am the 2nd owner of my S500 and have garage kept it for the past 15 years...I "only" have 125K miles and 100K miles of that is highway.
There is a safety switch that is in the shifter assembly that is very sensitive. Good luck with this and let us know what the outcome is. Mine started doing this about 6 months ago ...but only occasionally. Changing the Key Fob Battery helped. BTW, mine is a Keyless Go model.
There are two DIY fixes - purchase and install an aftermarket metal lever; or, remove the failed lever.
If you choose to just remove the lever, the shift lever can then be moved from PARK at any time, just as could the lever in the millions upon millions of cars built before 1968. If you are uncomfortable with this situation, you should replace the blocking lever.
There are at least three different lever designs, and no known way to tell which of the three will be in your car. As a result, there are vendors who sell a kit that includes all three levers, allowing you to dismantle the shifter, then immediately replace the lever with the appropriate version. Otherwise, you will need to disassemble the shifter, determine which lever you need, and let the car sit until you can procure the correct version.
While replacing the lever is not a really simple task, there are numerous videos on youTube showing how to do it. (Search for W220 shifter repair or similar terms.)
Thanks,
Valerie
