Kool Kellz
Once inside the car, the water will flow thru stamped channels in the floor under the carpet with no visible signs of water or dampness. Under the carpet and padding in the right front floor are the main electrical supply cables, with major fuses and connections. The water will cause corrosion and damage here.
The water will also flow all the way to the rear seat. Under the right side of the rear seat is the rear SAM (Signal Acquisition Module), which contains numerous fuses and control modules. The water will cause corrosion and damage here.
There will be no visible signs of water.
You must pull the right front carpet and padding/insulation, and remove the aluminum cover and check very carefully for water damage and corrosion. If water has gotten in, you will need to thoroughly dry the carpet padding and insulation, or there will be continued damage. You will need to test the fuses and connections, and they will normally require disassembly can cleaning. Use caution - you are dealing with cables that connect directly to the battery, so you need to disconnect the battery ground cable and secure it so that it can't creep back into connection.
If there were traces of water under the carpet, you will probably have to pull the rear seat (there is a release at each forward corner of the lower cushion) and check the SAM for corrosion and damage. Some folks have had good luck by disassembling and cleaning the SAM, others have chosen to (or were forced to) replace the SAM. You will need the same part number, and will normally need to reprogram some of the control modules using SDS (the dealer-level computerized diagnostic system).
An on-line search for "W220 water damage" will result in numerous hits. Good luck!
You should have a fuse chart in the tool holder in the trunk. Pull each fuse (one at a time!) and check for corrosion or a blown fuse, then reinsert. Do every fuse on the car - the lines under the floor, the fuses behind the trunk lining forward of the battery, the two SAM units under the hood, and the fuses in the rear SAM (behind the floor light behind the right rear passenger's heels).
If this does no good, you will probably have to find someone who has SDS (the dealer-level computerized diagnostic system) to find the problems.
pull Up the rear seat bottom (there are release clips on both outer edges of the seat bottom you need to release then lift up seat bottom )
then the sam unit with fuses and relays will be exposed . Check for dampness and also check for corrosion in the wiring harness plug that connects to the sam
