Door control module
Old May 5, 2021 | 01:44 AM
Rollerman's Avatar
1998 C240. 2000 S500
Angry Door control module
Hi all,
I have a RHD 2000 S500 and it developed a fault whereby nothing would work on the left hand passenger side of the car. Various suggestions were made that it was a faulty DCM. I took it to the Mercedes dealers who put it on the Star scope and they said it was definitely the DCM. I purchased a new one only to find that it didn't fix the fault.
Since then I have replaced both control modules and all the other switches from a donor car that was tested and all the switches worked perfectly. I still have the same problem, nothing on the left hand side even after swapping everything back to the donor car and finding everything working ok.
I have replaced the 40 amp fuses in 13 and 39 per the fuse chart but still nothing.
What am I missing? Is there another fuse or relay that I should check? If so, where is it located?.
I now have two sets of modules and switches but they won't work in my car so any help from anyone would be greatly appreciated.
Thanks,
Rollerman.
Old May 9, 2021 | 12:47 PM
Kebowers47's Avatar
001 s600, 94 sl600
It seems clear there is a broken wire/loose connection somewhere in the wiring between the two doors. There is no easy way to trace the wiring, but it must be done. The wiring probably runs through the Signal Acquisition Modules. Good luck and good hunting. I would first check all the relays.
Old May 10, 2021 | 10:32 PM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
Are the door modules that you got from the same year? Pre-facelift and post-facelift are different.
What does DAS say now?
Old May 11, 2021 | 04:04 AM
Rollerman's Avatar
The other modules were from exactly the same model, year series as mine and the part numbers are also identical. I tried my door control modules and switches in the donor car and they all work so it can't be those that are faulty.
Going to spend the weekend trying to check all the fuses and relays before I tackle the wiring loom. I'm running out of options and the dealer is being no help whatsoever as he wants to sell me a new DCM but has no idea which side I need.
By the way, what is a DAS?
Old May 11, 2021 | 07:27 AM
Astro14's Avatar
Veteran: Navy
DAS/XENTRY is the Mercedes Dealer software that was used to troubleshoot the DCM when you brought it in.
Troubleshooting complex electrical issues, like yours, without it, is shooting in the dark.
