Serpentine belt
You did get routing right? It started and went around then slipped off easily. I failed even though I’d taken a picture until I saw this 🙄 You have to get the tensioner to the max and put a pin in put belt in place then pull pin. Easiest way unless someone helping. Hence in pic of tensioner see supplied at full compressed..
1. Routing Pic
2. Eg Can see my water pump skewed in
3. A12 star ring spanner fits on tensioner and didn’t use the female hole rather the one that stuck out on mine.
4. Learned from looking for a 12 star multi point 17 socket all these bolt heads will fit that ring/socket
5. What my tensioner looked like 03 S320cdi
6. Spline I was going to use until I counted a ring spanner and it clicked. This idiot hadn’t seen that for years 🤔🤨🙃
Mine had another tensioner pulley at 1oClock too.
Hope that helps you.
Have a good one
wallyp (01-26-2022)
2003 S500 2007 GL450
Good post!
In my case, the air conditioning compressor locked up.
With the belt off, every pulley driven by the belt should turn smoothly and quietly. Replace any that make noise or are hard to turn (the compressor will be a bit stiff, but should turn smoothly).
