Re-clocking/ aligning the steering wheel on a W220?
Old Apr 12, 2022 | 04:46 PM
PrometheusFD3S's Avatar
2006 S65 AMG, 2001 S600, 1995 RX7, 1994 840Ci, 1975 XJ6-C, 1971 Celica Coupe
Quick question: Are you able to re-clock the steering wheel location from the upper column/ steering wheel?
I dropped my subframe & when reinstalling the lower slip yolk/ spline, I didn't get imperfectly straight (it was a bit of a pain in the butt & took 2x people. I', wondering if I can just it from above by removing the steering wheel & adjusting the spines at the wheel itself, instead of having to drop the subframe again & deal with all of that mess.
I saw in this video that there is a splined hub, with a 0 degree & 180 degree missing spline, I aim wondering that will not allow for adjustment.
Old Apr 13, 2022 | 03:02 AM
tim687's Avatar
CL 600 '00 5.8L V12
I think that should allow for adjustment. Just remove the steering wheel, move it one or two splices over and install it
I'm not sure if that's the proper way to do any adjustment though xD
Old Apr 13, 2022 | 09:59 AM
wallyp's Avatar
2003 S500 2007 GL450
Not a good idea. There are sensors in the system that will be displaced, and if the steering rods are different lengths, handling and tire wear will be affected. Fix what's wrong.
