door seal
Old May 31, 2022 | 12:03 PM
OhYou_'s Avatar
s430
door seal
what seals should I order to make my door stop making wind noises?
I just put on order a 2207200178 which seems to be the main gasket, but are there any others I should also replace?
It's quite bad even at normal speeds, and the car is deafening at 150+mph, the door may as well not be there.
there is this part #3 in this illustration but I cant seem to find what it is called and every parts site has completely ruined their catalog systems so i basically cant even find any parts now.
Old Jun 4, 2022 | 04:43 PM
AKA FACE's Avatar
Mercedes s500 2002
Unhappy Mercedes s500 2002 driver door sucks then opens
Please help me - the door sucks in then slightly opens triggering door open on dash locks work up or down but door doesn’t hold air seal in
i have done the fuse thing - can’t be pump or actuated because the others are working just the door closes and seals then slightly opens back up what could it be help please losing my mind d
Old Jun 5, 2022 | 09:32 AM
wallyp's Avatar
2003 S500 2007 GL450
Normal operation appears to be sucking in to latch, then relaxing slightly so that the mechanical latch, not the pneumatic actuator, holds the door in position.
If you shut the door firmly, does it still show the "door open" warning? If so, sounds like a maladjusted door latch.
Old Jun 5, 2022 | 10:47 AM
chassis's Avatar
2017 GLE350 4MATIC
Buy WIS/ASRA/EPC from ebay and you will have the entire parts catalog.
Old Jun 6, 2022 | 05:50 PM
OhYou_'s Avatar
s430
cost mone
anyway it didnt fix it but made it slightly better, and the issue i guess seems to be the weatherstrip that runs all along the roof and pillar line is just hard and no longer making good contact.
I cant find a part number for it though, and it's probably really expensive
Old Jun 6, 2022 | 08:38 PM
wallyp's Avatar
Sounds as if someone didn't understand the consequences to owning a Mercedes...
