2001 s430 w220 PSE problem, misfire on 3, DRLs?
2) misfire 3 whenever i try to accelerate well, it stumbles. this week, putting in tune up: 16 wires and 16 plugs from FCP , and some liqui moly oil change wont hurt
3) DRLs are available on ebay, look real nice, however I have to tap into all sorts of wires. Like headlights and turn signals. Is this easy to tap into the harness or best left to the professional?
Thank you all
Look for a U-Pull-It Yard within a reasonable distance. Pulling the PSE pump is quick and easy. If no luck there, try eBay. Be warned - it can difficult to get the replacement pump programmed to match your car. The programming is on the pneumatic valves, etc. - the pump itself is not programmed.
