2002 w220 acceleration delay and shifter issues
Old Dec 22, 2022 | 06:04 PM
maha90's Avatar
2002 MB S500
Question 2002 w220 acceleration delay and shifter issues
hello mb lovers,
today I just found out that my 2002 w220 has some issues that i m not familiar with
- start accelerating, goes slow (5-10 mph like limp mode) for like 10 - 15 feet, and after the speed goes up normally
- I stop the car, trying to shift from D to P buuuut the car gets stuck in N. I turn off the engine, start the engine again in N, and will shift normally in P.
No check engine light
185000 miles
Any advice?
Merry Christmas!
Old Dec 23, 2022 | 09:12 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
If you have DAS or a Mercedes specific scan tool, check the ESM (shifter module) for a P1856 code. The optical pickups in the module have a solder issue and the shifter is not able to report its position. Common issue on W220/R230. Usually this is a momentary loss of position, but the code is set and will keep the car in limp mode until a key cycle. Could be something else, but this is the most likely.
