Engine stops when going out of D
Old May 12, 2023 | 08:30 PM
defalt's Avatar
2005 S 350 L W221 (1637th produced), 1981 300 GD and 1985 280 SEL in restoration
Hello everyone,
My W220 S 320 CDI (OM648) starts acting up... It didn't run for about a year, but it currently runs very smooth, no issues whatsoever. Had an EPC light at first for gear selector and turbo wastegate but I cleared them and they didn't come back (probably from sitting so long).
Problems started happening today, when I stopped the car and put it out of D, the engine instantly shut off as if I had pressed the Engine On/Off button, which I did not. Happened 3 more times today.
The idle is perfect, purrs like a kitten, engine makes its power, no gearbox issues, nothing.
What do you think it could be? Water seeping in the Keyless Go button when cleaning causing it to short? Or worse electrical issue?
Thank you very much
Old May 13, 2023 | 01:51 AM
Fried Chicken's Avatar
2005 S500 Designo
You say it turns off like when you push the power button? What if you give it a little gas (diesel)?
Old May 13, 2023 | 10:09 AM
defalt's Avatar
The thing is it happens randomly. Maybe one out of 10 times I shift out of D. I think it is more of an electrical issue, as the car idles great and never stalls outside of this precise situation.
Old May 13, 2023 | 12:05 PM
2005 S500 Designo
Very weird. I wish I could help further.
Old Jun 14, 2023 | 07:57 PM
defalt's Avatar
Turns out it was the Keyless GO button being very sensitive. Barely touching it caused it to trigger. Changed my hand positioning and all good
