Please post your a/c performance
Old Aug 9, 2023 | 03:57 PM
DimcheSRQ's Avatar
2001 S430 W220
I am trying to figure out if I am getting 'decent' or expected a/c performance in this hot as hell weather in my 01 S430. Sometimes I cannot figure out if that's just the way it is, or if there's a problem.
At about 100F outdoor with 30-40 percent humidity, when IDLING for 10 minutes, vent temps are around 60F. That's a -40F difference, which most a/c documentation says is adequate. When DRIVING, I am getting 50-55F at the vents which starts to feel good. 60F does not really feel cool to me. These values are after replacing the receiver drier and recharging the system to proper 34oz R134a spec. I also changed cabin filters. My 2015 Audi A5 gets to 40F vent temps with ease although we may not be comparing apples to apples here.
Would you think this does not cool enough? Should I look at replacing expansion valve or condenser to get better results?
Old Aug 9, 2023 | 06:50 PM
tusabes's Avatar
Mercedes
Originally Posted by DimcheSRQ
I am trying to figure out if I am getting 'decent' or expected a/c performance in this hot as well weather in my 01 S430. Sometimes I cannot figure out if that's just the way it is, or if there's a problem.
mercedes ac gets cooler when driving and hotter at idle . If you want cooler, replace your r134 with envirosafe. Costs $28 and takes 5 minutes
Old Aug 10, 2023 | 04:03 PM
JB-HTX's Avatar
01 S430 Sport---- 23 S580 Sport
My AC on my 2001 S430 performs the same exact way. I honestly thought something was wrong with the compressor (2 years old), but apparently this is normal (?) behavior. In the morning and at night it blows ice cold though, so I suppose this is just the AC trying to overwork in the heat and when idling in traffic or at lights, the ambient air is being cooled enough when sucked by the fan. I guess the 105 degree weather and high humidity here in Houston doesn't help.
Old Aug 11, 2023 | 05:56 AM
ygmn's Avatar
2015 E400 Sedan
Add an electric fan to pull more air across condenser while stopped.
Sure it has one and maybe she is worn out or not coming on ?
Old Aug 11, 2023 | 08:20 AM
DimcheSRQ's Avatar
2001 S430 W220
It's blowing pretty strong. No problems there. I was thinking to do an evaporator flush with special foaming cleaner up through the condensation drain line underneath. Maybe after 23 years that thing has gunked up a bit.
Old Aug 11, 2023 | 11:52 AM
tusabes's Avatar
Mercedes
That’s not gonna get you colder, the $28 Envirosafe kit I posted above will get your colder. I’ve used it at least five cars.
Old Aug 11, 2023 | 01:08 PM
DimcheSRQ's Avatar
2001 S430 W220
Thanks. I'll pass on 134a alternates, I believe that they are no different than 134a performance. I tried Duracool a while back, and it actually got worse. They tend to be more flammable and a lot more expensive than a 12 oz 134 can at walmart.
Old Aug 12, 2023 | 04:11 AM
ygmn's Avatar
2015 E400 Sedan
cleaning coils is always good inside and out..
but think what is diffrent with AC performance:
One you sitting still
other you are moving..
so what is different is Compressor RPM and air flow across the condenser.
I think your AC may have the variable compressor and if it does maybe the control cartridge valve is going out and not changing comp. displacement larger with low speeds??
Or like I said early fan air flow is low due to fan or clogged coils??
Or crappy MB ac system design.
Old Aug 14, 2023 | 07:10 AM
tim687's Avatar
CL 600 '00 5.8L V12
It does
There is no fan on the condensor itself for the AC system, although, there is an fan on the radiator pack, which might be operated to increase cooling capacity of the condensor on hot days.
Refill your AC system with a UV die and check, with an UV light, if there are any spots on your condensor or any other place.
