2002 s500 fuses dead front passenger fuse box
Old Aug 21, 2023 | 04:19 PM
Mcaldwell's Avatar
2001 S500
I don’t have power going to half the fuses in front passenger fuse box. Original problem was radiator fan. Motor went bad, replaced fan now I have 12 volts feeding fan control module on big wire but the control circuit is dead on both sides of the fuse. When I started checking fuse I realized half the fuses in that fuse box are dead. Any help or things to check would be appreciated, thanks.
Old Aug 22, 2023 | 11:28 AM
wallyp's Avatar
2003 S500 2007 GL450
X4/10
Front prefuse box X4/10 (Circuit 30 and 61 terminal block and fuse box) is located underneath the passenger footwell carpets.
It has a high-capacity capacitor installed in it, so be careful with tools in the area. The capacitor is purely for smoothing voltage spikes to vital electronics.
Front footwell with carpets removed.
Front prefuse box.
Front prefuse box (X4/10) opened.
Front prefuse box (X4/10).
Front prefuse box (X4/10) opened.It contains 3 fuses:
  • X4/10f1 - 150A
    • Left front fuse and relay module
    • Engine fuse and relay box - Valid for S55 AMG, S65 AMG, and engine 275
  • X4/10f2 - 60A
    • Electronic ignition switch (EIS) [EZS] control unit - 60A
  • X4/10f3 - 150A
    • Right front fuse box and relay module
    • Alternator (B+)
    • Engine and AC electric suction fan with integrated control
Thick red wire goes to battery (unfused). According to wiring diagram, starter's B+ wire is connected to battery through this prefuse (unfused).
