Sir,
Right side head light full unit stops working except low beam and parking lamp
Any idea why this happening?
when keep the car without use for days...
WHEN FRESH START AT MORNING
When i turn key first turn.
(Two low beam want to work) But in my car only right side low beam works
signal light stops working
head light stops working
fog lamp stops
And if we wait for minutes we can see left side low beam flashing but not staying on. When i turn key to second position(engine on position) both right and left low beam works
but right side headlight unit only low beam and parking light works
Remaining all stop
no signal light
no fog light nothing but only low beam and parking light
One thing also i noticed that this head light issue only happens when i keep the car 3 4 days without driven
If i drive daily my car head light work fine as normally
Reason: TITLE HEAD LIGHT ISSUE
Welcome to the stupid ****show that is "xenon" headlights. I can't offer further help, but I can curse at this bout of automotive stupidity alongside you.
you have a short somewhere clearly. inspect all the wiring for fog , headlights. open and close connectors and spray down with solvent to clean, use a brush to get all the sand out? cooked wiring?
