2005 s600
Old Dec 16, 2023 | 11:06 AM
Sulciku's Avatar
2005 s600
2005 s600
Hello guys. I have a problem with my 2005 s600. I have a misfire at cylinder 1-2-3-4-5-6 from the start. Any suggestions or help will be appreciated. Thanks
Old Dec 16, 2023 | 04:07 PM
tusabes's Avatar
Mercedes
Most likely the coil pack, second most likely is the voltage transformer between the two coils. Look at www.v12icpack.com.
what I would do first is rent, his rebuilt, voltage, transformer from him, as it can be easily changed in five minutes on top of the engine. If that solves it, you keep the rental voltage transformer. If it doesn’t solve it, you return the voltage transformer rental and buy the coil pack.
This is the most common failure item of the car
Old Dec 16, 2023 | 08:39 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
start searching on these forums and you will find lots of info on this subject, which is not rare.
This is not Walmart.
Old Feb 1, 2024 | 03:14 AM
Hank Houston's Avatar
S-600 w220, Nissan s13 coupe, and Nissan s13 convertible
When you're misfiring from an entire bank then it's the voltage transformer.
Old Feb 1, 2024 | 09:07 AM
kraut56's Avatar
Do NOT change parts WITHOUT a SDS diagnosis (i.e. reading MB fault codes).
The ECU may be shutting down these cylinders deliberately to protect damage to the cats.
Old Feb 1, 2024 | 10:24 AM
Fried Chicken's Avatar
2005 S500 Designo
Exactly what Kraut said. Never throw parts at the problem, get a diagnosis first. A diagnosis over the internet is impossible, so find a mechanic that knows this platform.
