Car ran out of gas with gauge showing over a quarter tank
Old Dec 19, 2023 | 05:26 AM
Nemat Heydary's Avatar
W140
I was on the highway and the check engine light came on and then, less than a minute later, the car wouldn't accelerate, went into limp mode and gave me just enough time to get onto the shoulder. I thought it was the fuel pump and when my brother told me he added gas and it fired back up, I was pissed knowing full well the gauge wasn't showing below a quarter tank. What causes this to happen?
Old Dec 19, 2023 | 08:12 AM
Vin_16's Avatar
C-Class
Hi,, I hope this helps.. Your fuel gauge might not accurately display the actual fuel level in the tank. This could lead to your car running out of fuel even though the gauge shows a higher level.
To determine the exact cause of the issue and understand the error codes related to the check engine light and limp mode, it's crucial to retrieve the fault codes from the car's ECU. Using a full system scanner like the Youcanic scanner is an excellent way to pull fault codes from all control modules in the vehicle. These codes will provide more specific information about what triggered the check engine light and the loss of power.
Once you've retrieved the fault codes, they can offer a clearer picture of the problem.
Old Dec 19, 2023 | 01:08 PM
wallyp's Avatar
2003 S500 2007 GL450
first question - what car was this? Model, year, market...
Old Dec 19, 2023 | 08:33 PM
tusabes's Avatar
Mercedes
These are AI bots, getting ready to spam the forum with an advertisement for their scanner.
Old Dec 22, 2023 | 08:37 AM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
A bad fuel sender. What’s does your owners manual state for fuel capacity? When the car shows a quarter tank, how many gallons does it take to fill?
Old Dec 30, 2023 | 11:33 AM
raez77's Avatar
w220 s320
I have the same issue,
i changed fuel sensor, still same
i change fuel tank, still same
at last i found... the rear sam chnge it ,it works
Old Jun 26, 2024 | 11:11 PM
W140
2003 S430 USA
Old Jun 26, 2024 | 11:16 PM
W140
It's a 23.3 gallon tank and when just under half a tank it takes 18 gallons to top it off. It's been 7 months of just keeping it topped off to avoid another situation of getting stranded.
