Climate control & Window power loss while driving
2003 s430: Must be a major connection issue….its intermittent, most times it will happen after driving the car for a few minutes, A/C shuts off, power windows won’t go down, and the fuse panel under the rear seat makes a ticking noise for ten seconds.
should I replace the whole unit under the seat? When I purchased the vehicle (for $500) the car wouldn’t start so I replaced the fuel pump relay under the back seat and it started right up, while I was under there I saw some corrosion….is there a specific relay or fuse I should look at under the back seat?
thanks for your help, it’s very hot today I need that AC working!!!
