S600 only cranking
Old Mar 6, 2025 | 01:28 AM
V2inoV2nge's Avatar
S600 only cranking
Hey!
When my car gets warmer or achieves work temperature, then it stalls or only cranks when I want to start, no fault codes but ecu don't see engine speed then, can it be bad crank position sensor?
Old Mar 6, 2025 | 01:37 AM
Bigmak42's Avatar
2005 C55 AMG Brilliant Silver, 1999 C43 AMG Black
Originally Posted by V2inoV2nge
Hey!
is there an engine code ? are you able to scan the vehicle? it is most likely the crank shaft position sensor. the code will be something along the lines of “Cam sensor L5/2 signal not recognized”
Old Mar 6, 2025 | 01:46 AM
tusabes's Avatar
Mercedes
If it stalls and won’t restart when warm , then starts just fine when cold it’s your crank position sensor
Old Mar 6, 2025 | 02:37 AM
V2inoV2nge's Avatar
Originally Posted by Bigmak42
is there an engine code ? are you able to scan the vehicle? may be O2 sensor related but not really sure.
m137, yes I can scan.
Old Mar 6, 2025 | 02:54 AM
Bigmak42's Avatar
yeah it’s most likely the crank shaft position sensor. lucky for you that part is pretty cheap and mercedes dealership should have it in stock.
