rear sam
Old May 25, 2025 | 04:05 PM
texasplayer's Avatar
rear sam
Looks like rear sam got wet. So need to replace it. Will replacement need to be programmed?
Also - my module has the number A0285458132 on it.
from researching It seems I can use any of the Rear SAM numbers A0205451932, A0315451632, A0325458432?
Old May 28, 2025 | 10:46 AM
e350forme's Avatar
fleet
after all these years, everyone always says and knows the rear sams are ok to replace without "programming"
...and i tested it this weekend. and it works
looks harder than it is to re wire it just one strand at a time
my car does not die overnight anymore. mine was dry
Old Sep 9, 2025 | 10:08 PM
Isabella G's Avatar
GL 550
Did you have a problem finding the right one with matching part number? I’m stuck not being able to find anything. Does your MB start every time now?
Old Sep 10, 2025 | 10:47 AM
e350forme's Avatar
fleet
this is for a very specific year of s class, are you sure you have the right part of forum
w220 is where you landed so 1998-2005
anyway, the part number is clear to see even without removing the module fully. same procedure for any model though.... locate the right module, take a picture, post here if needed, parts are plentiful these are not rare birds at all . if you have a GL that forum will have to help you, maybe its a common issue maybe not right. dont let it stress either. this most likely will be more difficult to work on a GL than an old S, no reason you cant figure it out these days with AI, free diagnosis from shops or dealer, forum posts, insta ect....... if you really cant drive whatever benz you have, there are many ways the forum can help you track down whats up, assuming you have a spare car in the meantime (hopefully another half working benz)
there are other "intermittent start" situations but this was just a draining battery from a bad sam until it was jumped ect
