2002 S55 PSE Pump keeps sucking
Old Jul 31, 2025 | 10:10 AM
isaiah1306's Avatar
2006 CLS55
I have a 2002 S55 and the old PSE pump motor burn so i found a new one ($40) off a parts car and plugged it in. After i replaced my fuse the pump started running and i found out my front multicontour seats had tears in the lines and they would leak air but then it would stop and my locks, etc would work but then a few minutes later it would blow the fuse. so i fixed those with end to end connectors, but now, my pse pump just keeps sucking in my truck then blows the fuse. I replace the fuse and the pump just starts running and then blows again. Is there something I can disconnect to get my seats to stop drawing air if thats what my issue is?
Old Jul 31, 2025 | 08:18 PM
Alexie's Avatar
Disconnect the air lines to the front seats usually under the seat and cap them off. If the pump stops blowing fuses, the seats were the issue. If it still blows, check for leaks elsewhere door locks, trunk, etc.. Could also be a bad replacement pump.
