W220 limp mode
I recently discovered transmission fluid had wicked up the wiring harness and made its way into my Transmission Control Module (TCM), which I am currently addressing, but I want to lay out all the codes to see what else I should look out for (like the Front Passenger SAM module).
Here are the exact codes pulled from the scanner:
Engine / Powertrain Control Module
P202E-008 [State: Current and Historic]
Description: M16/6 (Throttle Valve Actuator) : Deflection Of Throttle valve (P0120)
P2006-002 [State: Historic]
Description: [B17/8 (Charge Air Temperature Sensor) : Short Circuit To Positive Or Open circuit (P0112)] or [B17/8 (Right Charge Air Temperature Sensor) : Short Circuit To Positive Or Open circuit (P0112)] or [B2/5b1 (Intake Air Temperature Sensor) : Short Circuit To Positive Or Open circuit (P0112)]
P2031-004 [State: Historic]
Description: No Or Incorrect CAN Message From Control Unit N80 (Steering Column Module) Communication Fault / See Also CAN Status In Freeze Frame data (P1999)
Drive Authorization / Shifter Module
P1925 [State: Historic]
Description: Drive Authorization Has Been Refused By Control Module N15/5 (Electronic Selector Lever Module (ESM [EWM]))
P2600 [State: Historic]
Description: The Voltage Supply Of Circuit 87 Has Undervoltage.
P2602 [State: Historic]
Description: The Voltage Supply Of The Valves Is Faulty.
Current Symptoms & Notes:
Scanner Voltage Readings: Showing ~12.4V with ignition ON, engine OFF.
Found Issue: I pulled the TCM and physically found transmission oil inside the module/connector (wicking up from the transmission pilot bushing plug)
