W221 S-Class Official Picture Thread
#678
The best bet to wire it,is to tap into the foot light inside the passenger area. That way you don't need to use any resistors which get extremely hot and cold melt what is around it? I recently had to do it to mine because the resistors I were using kind of melted the del housing.
Btw the auto on/off relay that one of the members suggested do not work. I tried 2 sets thinking the 1st set was bad.But it still did not work on the 2nd set.
#679
toyota sienna, S550, Subaru Outback
#680
The drl light turns on automatically once the headlights are on. Or I can turn it on manually by switching the light switch on? Another method I had in mind was to tap into the cig acc outlet. But the light will just be on,and I won't be able to switch it off manually. Another reason why I tap into the footwell light,is that when I unlock the car,the drl light will turn on and act as a pathway lighting?
#681
2007 SL55 AMG
#683
#687
Comparison Between Mercedes Benz W221 S65 AMG and BMW 760Li F01/F02.
see which 1 is better!!!!!!
http://goodcar.us/?p=121
W221 <3 i love youuu
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#689
s550
thanks.. yea, its Brabus Original. i bought it directly from brabus-usa.
http://www.brabus-usa.com/
#699
I would like to see more pics too..thinking about wrapping mine..
phat have you heard of any negatives of wrapping your roof? Like weather, sun, snow, salt, etc..will it ruin the pain if removed?
Thanks.
Thanks.
#700
As long as the wrap is installed correctly,you should not have any lifting or problems. I don't have any problems so far. If you ever need to remove it. I suggest to use a steamer. That way you get most of the sticky residue off. It won't damage your paint.
