command aux
Old Sep 14, 2006 | 03:18 AM
skd's Avatar
skd
2007 S350L
command aux
If i wanted to add something to the aux of the command would that be located in the boot or at the front of the car + would the command have an aux port?
Old Sep 14, 2006 | 10:31 PM
hcwong's Avatar
Bentley Continental GT 2004
I have the iPod integration kit installed in my car. It goes into the COMAND aux input, which is in the front in the dash.
Old Sep 15, 2006 | 04:07 AM
skd's Avatar
skd
2007 S350L
hmm so would you think this idea would be feasible: Having a a small amplifer placed in the compartment where the fridge would be. Having this connected to the rear dvd and then to the command aux input, and connecting this to the battery?
for me it all sounds daring i have no idea of how to wire this stuff, im at last resort.
Old Sep 15, 2006 | 08:39 AM
rgbyhkr's Avatar
2004 S55
See the online manual here:
http://www4.mercedes-benz.com/e/cars...ensystem3.html
Page 89 has a section titled "Audio AUX" where it says:
"You can connect an external audio source (AUX) to COMAND. Please consult a Mercedes-Benz Service Centre for further information."
I see what you're trying to do as a workaround to give you the ability to play the RSE audio through the system's speakers. The question is how easily you can extract the audio from the RSE system. Obviously you have audio out connections from the headphone jacks so maybe those can be split. Or, perhaps there's a secondary audio out on the RSE that is usually used to connect it to COMAND with the 810 option your vehicle doesn't have. You may not need an amp as long as the volume on the audio output from the RSE is high enough since any incoming AUX signal will be amplified and have volume control through COMAND.
Jeff
Old Sep 15, 2006 | 08:51 AM
benzmodz's Avatar
W203 slightly modified
The Euro version has no problems since there is a TV tuner option and 2 AUX inputs.
Old Sep 15, 2006 | 02:26 PM
skd's Avatar
skd
2007 S350L
yes ure rite i think there should be another output on the rse dvd player. but for now i think im out of options. Due to the fact that MB service HK wont touch it and ihave no clue where to start or anyone who knows what they are doing
