Heated Steering Wheel
Old 10-23-2006 | 07:24 PM
bt1340's Avatar
07 S600, 14 SL550
Does anyone know the reason the MB Build your own kicks out the wood/leather steering wheel option when you select the heated steering wheel option. I am soon going to order a new S550 and desire both options. I have seen cars reportedly equipped with both. I am aware that in the past, both were not available.
Old 10-24-2006 | 04:14 AM
aschb's Avatar
CLK500 2003, S 600 Model 2007
My S 600 has wood/leather steering Wheel and the Heated steering Wheel as additional option. FYI: it takes about 5 seconds to heat up the leather part.
Old 10-24-2006 | 10:57 AM
bt1340's Avatar
07 S600, 14 SL550
Thanks for the quick reply!
Old 10-24-2006 | 05:14 PM
AsianML's Avatar
2007 E63
Never knew that!! I hated how in order to get a wood steering wheel, you had to delete the heated option.
Old 10-26-2006 | 12:25 AM
carsinamerica's Avatar
I think that, for whatever reason, it might not be possible to combine wood & heated steering wheels on the S550. When you look at the codes, you can't have a heated wheel with a S550 Designo, either. However, this is not true of the S600 (obviously, since it is heated and wood) or the S65 (where the wood/leather combo is standard [which is why the paddle shifters aren't found on U.S.-spec S65's: only a full-leather wheel can be paired with the paddles] but the heater is optional). Very peculiar, but that's Mercedes-Benz. Oh so luxurious, but teeth-grindingly bureaucratic in their Prussian way.
Quick Reply: Heated Steering Wheel
