brake dust
Old Nov 22, 2006 | 11:15 AM
sooners's Avatar
cl500-o5, s500 sedan-o4, new s550 sedan
brake dust
guy's does anyone have a solution for the always present and aggravating problem of brake dust, i mean one drive and there is a fine film of dust on thewheels after 3 or 4 drives they are covered, and that is some nasty shick to wipe off, how do u guys handle it.??
Old Nov 22, 2006 | 06:23 PM
bt1340's Avatar
07 S600, 14 SL550
I have owned MB's since 1982 and have never found a solution other than just cleaning them very well each time. It will come off easily if you stay on them. In the 80's I used a shield sold through the dealer that would keep most of it away. The wheels did not have very large openings at that time and they were not readily visible. In more recent times, the wheel show a lot of rotor and caliper and I think that they would look terrible to put it mildly. Not to mention the lack of cooling that the rotors would experience.
Keep up on them!
Old Nov 22, 2006 | 09:42 PM
04Fire's Avatar
'03 ML500 & '11 R350
I would replace the brake pads with a ceramic pad, I did this on my Crossfire(SLK) and the dust almost nevers shows up between washies. I used Rotex Pads from "Brake World". I'm sure others will have varying views on the subject, and I've tried most cleaners and replacing the pads was the only thing that works long time.
Hope this helps, Jason
Old Nov 22, 2006 | 10:08 PM
Chucky300's Avatar
2014 S550
Aren't Ceramic Brakes or Pads like 3X the price?
Old Nov 23, 2006 | 12:22 PM
stardoc's Avatar
Are you tracking your Crossfire? Ceramic pads are great for dissipating heat well, but do you find they stop better too?
Old Nov 27, 2006 | 08:34 AM
04Fire's Avatar
They don't stop better just about the same once you break them in a little you wont know the diffrence, except for the lack of brake dust.
Old Nov 27, 2006 | 08:39 AM
04Fire's Avatar
They are more expensive, but it's worth it once you don't have to clean the wheels every other day.
Old Nov 27, 2006 | 11:18 AM
sooners's Avatar
thanks for the replys, i will look into the ceramics, or just stay on it, thanksfellas.
