Garage door remote
Revolving Code Garage Door Opener
Go to the garage door opener you want to program, locate at the rear of the opener a button typically red or blue. It may be labeled "program", push the button and an LED may/maynot illuminate. Within 30 seconds follow your regular programing instructions.
Good Luck
Good Luck
Thanks, I'll look into that later today and then report back. Hopefully that button is there.
2002 S430, 2004 Cobra, 2004 Tahoe
I typically program the remote to the button first (even though it supposedly doesnt do anything), then I go and push the button on the back of the opener, then run back to the car and press the cooresponding button...it has worked every time but once, but the homelink system was messed up on the one it did not work on...good luck and let me know if you have any other questions.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Rolling code openers have a learn button, yes it may require a ladder to push button on the opener it's self.
Careful some time the "program button" sets the up/down limit.
Best to read all the printed material of both the controller and opener to save grief. Good luck!
I Just installed a Liftmaster direct drive jack shaft, I love it, so quiet.
http://www.liftmaster.com/cw/product...-id-42,00.html
2007 S 600 / '06 911 Porsche C4S cab
it's easy...
Park in front of the garage door you want to program.
Turn on the car's power, (doesn't have to be running)
then hold your hand held under the mirror and press the hand held button and hold it down.
At the same time, pick one of the mirror buttons (one of 3 for garage doors) and hold it down as well.
the little green light on the mirror will flash slowly , and keep holding buttons down. then it flases fast and you're done.
2008 S-550 AMG, 2008 GL450, 2005 Ford F-350, 1998 Bentley Turbo R, 1962 Bentley s-3 Saloon,
rolling codes
