Rear View Camera
Old May 8, 2008 | 04:40 PM
jbo's Avatar
jbo
CL500 W216
Rear View Camera
Anyone have any details on how easy it may be to retrofit the OEM reversing camera on a W221/W216?
I think my W216 is the later model and is fully loaded (excl Keyless Go and Camera) MB appear to have changed the camera setup. Earlier cars appear to have had a seperate modulator and camera and later cars have a camera without the modulator.??
Would i need ECU's etc or is there a way to just retrofit the camera on its own with a wiring harness.
Any help would be appreciated
Old May 8, 2008 | 07:01 PM
NJS430's Avatar
S550 / S430 / E320
[quote=jbo;2812766]Anyone have any details on how easy it may be to retrofit the OEM reversing camera on a W221/W216?
Try contacting these guys - www.midcityengineering.com.
I believe they have a solution.
Old May 9, 2008 | 12:57 AM
SUNILP's Avatar
2015 E250D
check the w221 section where I have posted pics of a retrofit. I used all original MB parts.
Old May 9, 2008 | 01:12 AM
XJ9's Avatar
XJ9
C350
07 w221/w216 can be programmed for camera using the SDS machine but you would need the factory park assist module and camera to make it work.
08 w221/w216 are SCN coded so theres no easy way to change the camera setting. There are aftermarket solutions to program the camera though. The 08 models dont need the park assist module either, just an aftermarket camera.
Old May 9, 2008 | 01:16 PM
jbo's Avatar
jbo
CL500 W216
Reverse camera
Sunil
I have seen your post on the retrofit. Could you provide a bit more detail on how you achieved this. i.e What parts did you need to buy and how it was all put together and programmed etc?
Many thanks in advance.
I have also put an enquiry into midcity for a solution as I was very impressed with their VIM221 Video in motion module.
