Telephone/bluetooth issue?
Old Oct 23, 2008 | 08:26 AM
mmehtas's Avatar
2014 S550; 2008 E350
Driving to work this morning and got a call from home. Answered the phone and I could hear my wife fine, but she could not hear me at all. Called back 4 times with the same result. Turned the bluetooth off and on on the phone and still the same issue. The voice command works fine, so the microphone is working. Also made calls from the phone without bluetooth on and everything was normal, so the phone works OK.
Any ideas? Did I turn off something? Appreciate any thoughts.
Old Oct 23, 2008 | 12:53 PM
Diesel Benz's Avatar
Did you accidentally mute the microphone? I'm not sure if it remains muted from one call to the next though.
Old Oct 23, 2008 | 01:56 PM
mmehtas's Avatar
Thanks for the reply. No - I checked to make sure the microphone was not muted.
Old Oct 23, 2008 | 02:35 PM
Next guess would be the BT adapter connector. Perhaps a bad contact on the microphone signal pin? Should you try removing the adapter, cleaning contacts and retrying?
Old Oct 23, 2008 | 10:01 PM
mmehtas's Avatar
Weird, but it resolved itself.
Driving home from work, the phone was not "connected" automatically as it usually is. After turning the bluetooth off and on on the phone, it finally connected. After that every thing seems to function as normal.
Not quite sure what the problem was since the phone connected fine this morning and I could hear the caller but I could not be heard.
Anyway, thanks for the help and I hope the problem does not reoccur.
Old Oct 23, 2008 | 10:07 PM
trumpet1's Avatar
2007 S600
Electronics
Old Oct 24, 2008 | 01:53 AM
Originally Posted by trumpet1
Electronics
Are you suggesting the phone system would be better if it was not electronic?
Just kidding, but it could have been a mechanical connector issue instead of a control box being confused. Hopefully it does not come back anyway.
Old Oct 24, 2008 | 07:20 AM
trumpet1's Avatar
2007 S600
LOL. You're right, hopefully this is just a fluke and it's over. With all of the computers and electronics on these cars, it would be tough in some cases to figure these type of problems out.
