End of a perfect record
Old Nov 5, 2008 | 03:33 PM
NJS430's Avatar
S550 / S430 / E320
Well after 14 months of ownership I had my first problem with my 08 S550 yesterday. Started the car after voting and the dreaded "Engine Malfunction" light stayed on. Nothing detectable with regard to performance, but the light stayed on all day.
When I started the car this morning the light was out. Stopped at my dealer without an appointment on my way to work and they took the car right in. Turns out it was an exhaust CAM solenoid which they replaced under warranty. Had me on my way in an hour and a half. All and all I can't complain. This is the one and only problem I have had and it was taken care of promptly.
In speaking with the shop foreman, I sensed that I was not the first to have this problem. So if any of you experience the same, suggest you make a trip to the dealer.
Old Nov 5, 2008 | 05:20 PM
CynCarvin32's Avatar
Mercedes Benz
Happens to all the 272/273 motors. There is a campaign out for this issue.
Its a problem with the magnate that senses the position of the cam adjustments.
They should replace all 4 but the factory has gone el cheapo and will only change one per check engine light. Even with more than one registering an error they ask the tech to change one, reset the codes, and then send the car on its way hoping the other just gets itself back in order.
Design has been changed so hopefully you wont be back in again with the same issue.
Old Nov 5, 2008 | 06:34 PM
trumpet1's Avatar
2007 S600
I'll have to admit I have never heard of such an animal as a cam solenoid. This is totally new to me.
Old Nov 6, 2008 | 12:06 AM
AustinGuy's Avatar
'09 S63 AMG
Does the S63 AMG have a 272/273 motor? I need to know if I should take mine in
Old Nov 6, 2008 | 09:35 PM
Satan's Avatar
I can't afford
Do you have a check engine light on? if not there's no reason to take it in.
Old Nov 7, 2008 | 11:24 AM
MB Fanatic's Avatar
4 wheels
Our engines are completely different from that of the S550/S600/S65.
Here is some light reading for you: http://www.worldcarfans.com/2050713.001/1.html
Old Nov 7, 2008 | 12:21 PM
Diesel Benz's Avatar
Volvo S80 - wife
E320 Bluetec - mine
CL63 AMG - mine / wife
GL550 MY09 - wife
SL63 MY09 - mine
CLS 55 K4 - mine
An important off topic question for clarification: from your signature I can count how many wives you have but I've never heard of a schizophrenic with so many different personalities.
Kidding of course, just jealous.
Old Nov 10, 2008 | 01:55 AM
CommanderCody's Avatar
2016 GL63 & 2008 S550
same issue.
I just went through this with my GL550 (same motor as you mentioned). I guess I got lucky, as the dealer replaced all of the sensors on mine. It must be an easy task to repair, as I got the vehicle back within hours of dropping it off.
