Unknown switch in center console ...
Old Apr 2, 2009 | 11:23 PM
Mandingo's Avatar
W222 S63 AMG
When I open the center console there is a big selector switch in the front of the bottom section with positions "0" and "1".
I looked through the manual but I have no idea what this does.
I am sure it is something obvious but I can't work it out.
Can someone please enlighten me?
Old Apr 3, 2009 | 01:22 AM
Diesel Benz's Avatar
You should find it from the user manual. The switch controls air flow to the centre console compartment. If you want it to be cooled in the summer, put it to open position (1). Good for storing soft drinks or so.
Setting the stowage compartment air vent
The stowage compartment can be ventilated, for instance to cool its contents, when the automatic air-conditioning system is activated. The level of airflow depends on the airflow and air distribution settings. The temperature of the air is approximately the same as that of the air flowing from the centre air vents.
Close the stowage compartment air vent when heating mode is activated and activate the "cooling with air dehumidification" function if the outside temperature is high. Otherwise, temperature-sensitive items stored in the stowage compartment could be damaged.
Stowage compartment air vent
To switch the ventilation on/off: push rocker switch down or up .
http://www4.mercedes-benz.com/manual...html#d13e52826
Old Apr 3, 2009 | 10:21 AM
Mandingo's Avatar
W222 S63 AMG
Thank you! - I have lots to learn still.
I love this forum
Old Apr 4, 2009 | 02:13 AM
s600ed's Avatar
2007 s600 2007 cls63
Pardon my ignorance.....why dont I have that in my car? All I see is the part that protrude to attach to either the BT or cradle.
Old Apr 4, 2009 | 03:14 AM
You have the S600 with all options, including the independent rear heating (don't remember how it is called). The heater core would take the storage space. But we can always swap cars if you want that feature.
Old Apr 4, 2009 | 11:21 AM
s600ed's Avatar
given the exchange rate and how the W221 prices has crashed in the US, this is actually bad deal for you!!
