W221 Auto-headlights problem
Old May 2, 2009 | 08:00 AM
zuby84's Avatar
BMW
Hi, I have a 06 S320 cdi and have a problem with the auto headlamps where no matter where the switch is the lights won't switch off until I switch off the car so currently during the day I am driving around with the xenons/sidelights on all the time (the green light below the switch remain illuminated even when on the off position). Anyone know what could be causing this? One of the number. Any ideas?
Old May 2, 2009 | 08:46 AM
WingFlex's Avatar
Sonderklasse
Did you accidentally activate the daytime running lights via the cluster menu?
Old May 2, 2009 | 11:13 AM
itschase's Avatar
S600
Daytime running lights should not cause the green light to be illuminated on your switch. Sounds like a faulty light control module. On cars like these 'switches' do nothing more than send a command to a module, if the software in that module it out of whack - issues like this will arise. Dealer time, unfortunately.
Old May 2, 2009 | 11:14 AM
Diesel Benz's Avatar
It should not have been accidental but intentional, soon also mandatory throughout Europe.
Anyway, you said it more politely than "read the xxx manual".
Old May 2, 2009 | 11:16 AM
Honestly I've never looked at the green light, will have to go and test in the car.
Edited: test performed, at least on my car the green light comes on when ever the lights are on (parking or full lights), irrespectively if they come on with DLR set on and the switch at "0" position.
Old May 2, 2009 | 08:14 PM
softgenious's Avatar
07 S550
You have it set for the daytime lights on.
Old May 3, 2009 | 01:39 PM
steveb9771's Avatar
2007 CL550
What country are you in? S320 models are not available in the US. It appears to be daytime running lights. They can not be turned off for cars built for some countries. Cars built for Canada have the feature to turn them off not available. Cars for the US market can turn them on or off from a menu controlled by the left buttons on the steering wheel.
Old Dec 19, 2012 | 05:09 PM
Zerocarpileup's Avatar
2008 S63
Having the same problem. My light switch will not work at all and is not illuminated at night. Also my lights are on all the time. I'm noticing the parking brake beneath it and the red SOS light above me are blinking for a moment. Any one with any ideas what this could be? Relay, fuse or switch?
Old Dec 19, 2012 | 10:39 PM
2008 S63
I don't have a green light. The whole switch is not illuminated. I have no control at all.
Old Jan 3, 2013 | 06:32 AM
2008 S63
Can any one help. On my 2007 mercedes s550. My light switch is not working nor illuminated. Light stay own all the time without being able to switch them off unless car is on. Cannot choose to power fog lights either. Upper dash options inoperative nor illuminated, ESP, air ride lift, etc. center clock and parking brake not illuminated. Could this be a relay. All fuses look good.
Old Jan 3, 2013 | 06:37 AM
2008 S63
I'm looking on them fuse chart (PDF version) and it does not show relay information at all. I'd like to see what all they control. This is NOT a daytime running light issue.
Old Dec 9, 2013 | 10:27 PM
Mr Lott's Avatar
2007 S550
do anyone have a video or a diagram on how to replace the front headlight on a 2007 s 550 Mercedes I quite don't need to replace the front light but I need to replace the brake park light
