Help pls ... W221 Lumbar seat function not working
If I use COMAND to go into the settings as per the screenshot below, the scale from 0,1,2 ...10 can be changed using the dial wheel.
However, when you move the dial to any position from 1-10, it does not STORE/SAVE that position and I can see that there is no movement of the lumbar in the seat itself which may be why it's not saving it.
If I repeat the same process for the Passenger side, the seat makes noises and sure enough, you can save the setting to the position you want.
Anyone got ideas on what could be the problem on the Driver's side please and how easy to fix? Is it electrical or mechanical? Thx.
