2007 s550 Navigation/Gas Pumping Question
1. What is the cheapest way to upgrade my navigation and how do I go about doing it
2. Can I upgrade the navigation without upgrading the command center software?
3. Has anyone had a problem of pumping gas and the pump shutting-off (like it does when the tank gets full) many times prior to being full?
Thanks.
2.. the nav upgrade is a separate upgrade from command upgrade.
3.. I have the same fueling problem on my 2007 S550. some pumps must trip out real easy.. I have found if I dont stick the nozzle in all the way it will usually fill ok
#3 I had the same problem on newly acquired used 07 S550 40K miles (not sure if the prior owner complained about this or not? There weren’t any service notes in the history about gas pumping problem) and after complaining to the service department that I wasn't able to pump gas in my car they went ahead and installed a new gas tank and that fixed my issue. So I would recommend if your car is still under warranty you should talk to your local dealership.
