Tuner Cost
Old Oct 3, 2010 | 02:11 PM
S5502007's Avatar
S550 2007
Tuner Cost
Hi guys,
What does a tuner cost? Looks like mine needs to be replaced. Has this happened to anyone yet? There is no sound coming from my speakers and when they connected the diagnosis equipment, there is no response from the tuner...so this may be the reason.
Old Oct 3, 2010 | 04:17 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
The tuner wont show up on a pre 2010 S class. That is a nonUS tv tuner.
Nick
Old Oct 4, 2010 | 08:24 AM
S5502007's Avatar
S550 2007
Hi Nick,
It's not the TV Tuner I am referring to, that is separate on the diagnosis machine. What I am referring to is the audio tuner located on the left panel inside the trunk.
Has anyone changed this before? Could it be caused by a low battery?
Old Oct 4, 2010 | 09:25 AM
Diesel Benz's Avatar
Originally Posted by S5502007
Hi Nick,
I guess you did not have low battery during diagnosis. Temporary power loss would not disable the tuner. Did you check the fuses and the connectors? How about other MOST ring devices?
Old Oct 4, 2010 | 03:12 PM
S5502007's Avatar
S550 2007
They coducted a low battery test and I had the rear battery replaced. I received a quote for a new Amplifier...$2800 CAD!! Is this the only option? I cannot believe that an amplifier would have to be replaced on a three year old model...has anyone had to look into an amp replacement before?
Old Oct 5, 2010 | 01:45 AM
Did you have a look at the tuner? Sometimes water kills control units when drain pipes get blocked and water gets collected to the area where the control unit is located. Incorrect jump starting could kill control units too. Otherwise three years should not make it any worse than on a new car.
Old Oct 5, 2010 | 09:06 AM
S5502007's Avatar
S550 2007
Where are the drain pipes located? I want to make sure that if replaced, it does not happen again. They are 99% sure it's the AMP and says that it can go if the battery is low or if has been abused. I recently picked up my S550 07 and it went through all the MB servicing but not sure how it was treated by the previous owner.
Has anyone replaced their Amplifier before?
Old Oct 14, 2010 | 08:31 AM
S5502007's Avatar
S550 2007
I ordered a used amplifier and it arrived yesterday. I'll be installing it this weekend and will let you know if it resolved the audio issue...I sure hope it does.
Old Oct 14, 2010 | 10:19 AM
jbondox's Avatar
beater with a heater
just had a buddy in Staten Island have the same issue. It is pretty worrisome having heard 2 within 2 weeks.
Old Oct 18, 2010 | 11:52 AM
S5502007's Avatar
S550 2007
Just an update folks for those who have been following. I had my amplifier replaced on the weekend and it has resolved the audio issues. Big relief.
