Oil showing low
Old Nov 11, 2010 | 08:01 PM
MJM219's Avatar
2005 E-320cdi
Oil showing low
Just changed my oil,, filter and put on a set of those Akebono pads all around. I put in 9 qts, ran engine up to temp let sit and checked level. It is VERY close to the minimum level???
Shouldn't it be full???
Old Nov 12, 2010 | 02:44 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
Not sure what the specs are for oil capacity, 9 or 9.5, but check for leaks, if none found add oil at small increments but not too much since you will get a message that oil level is too high. Adding is easier than taking oil out.
Good luck!
