Help with headlight conversion harness installation
Old Nov 24, 2010 | 06:30 AM
FJT's Avatar
FJT
2008 S63
I ordered the harness to convert my headlights to the current model leds. I am hoping there is someone out there who is knowlegdable with this setup. I had my independent mechanic do the hookup to the STaR but he has run into difficulties. He sent me what he did below.
Removed 8 individual pins from old harness. And installed in empty plug on new harness. Ground harness left and right.
Ran wire bus to front sam and installed corresponding wires into individual plug connectors on sam.
Connect star diagnosis.
Enter sam and it says wrong control unit version.
Push continue.
Go into control unit version and nothing is highlighted.
And control unit is recognized.
Go into control unit adaptations and it directs me to SCN coding automatically.
Try to perform and will not let me.
Go into initial start up. And same thing happens.
Go into headlamp control unit and star diagnosis will not let me enter.
Is there something he has to do in EZS or central gateway?
Any thoughts on next steps?
Old Nov 25, 2010 | 09:52 AM
Ahmedito's Avatar
07 S550, 08 Escalade, 08 H2
Push continue.
Where did you get your harness from? Did you change the Front SAM?
Old Nov 25, 2010 | 10:51 AM
FJT's Avatar
FJT
2008 S63
Got harness from Mastertuning with sam. Thanks
Old Nov 25, 2010 | 06:05 PM
Ahmedito's Avatar
Ok. Did you switch the wires on the headlight plug and on the SAM?
pm me your number and I will help as much as I can
Old Nov 25, 2010 | 06:16 PM
FJT's Avatar
FJT
2008 S63
Just sent you info
Old Dec 14, 2010 | 01:18 PM
Jessieg1299's Avatar
S550
Plug and play harness?
[QUOTE=FJT;4369424]Got harness from Mastertuning with sam. Thanks[/QUOTE
Do you have the number to mastertuning? I tried reaching them but had no luck. Only thru email. Did you do the upgrade already? Any info you can send me would be much appreciated, thanks, Jessie..
Old Dec 15, 2010 | 02:50 AM
JonMBZ's Avatar
06 C55, 09 E350
You cannot SCN code a control module with incorrect software for that year/model. This has been a long running issue. The only work around at least for the rear was to put it in a 2010 vehicle and do the SCN coding. I have never seen the attempt yet, but I haven't followed the progress in a long time to tell you any other info.
