Auxillary water pump location
Old Nov 29, 2010 | 10:21 PM
platt-deutsch's Avatar
2019 S450
Anybody know where the small aux water pump is located on a 221 2007 ?
Its the pump that circulates water through the heater core when in REST mode.
Old Nov 30, 2010 | 02:12 AM
Diesel Benz's Avatar
In the middle area in front of the firewall. Would you mind explaining why you are interested?
Old Nov 30, 2010 | 01:23 PM
2019 S450
When using the REST mode it only gives heat for a min or two so I assume the pump is not running. Had similar issue with my 2003 220 and that was the problem with it. Aparently this pump is located in the same area.
