Hot Weather - Fan Running???
Old Jul 7, 2011 | 10:14 AM
IDriveAnM5's Avatar
'10 S550 4Matic, '06 BMW M5
Exclamation Hot Weather - Fan Running???
Hey Guys,
So the weather outside has been hot around here. Regularly, it gets to the mid-eights or low-nineties. As of today, my S550 has been running the main fan at what seems to be a very high rate (because it is noisy as hell) when I shut off the car and walk away. It does this if it has been running for any amount of time.
For instance, this morning I left home (so the engine was "cold") and drove to the sitter's house. That drive takes about 1.5 minutes, and is just over 1 mile away. The main fan ran for between 1-2 minutes.
So the question: Are others experiencing this in the hot weather? My M5 does it all the time in the warmer weather. Should I be concerned at all? I feel the answer is "no," however since the fan runs so fast, it is just noisy and kinda makes my nice, classy car seem a bit stupid. That's all. No error lights, warnings, or codes thrown.
Thanks!
Old Jul 7, 2011 | 12:37 PM
fbracer's Avatar
2018 C43 Convertible
If it does stop after a while it should be OK. I don't know about all these electronic thermostats but, in regular cars fans are (indirectly) tied to thermostats and when they go bad sometimes the fan runs unneccessarily.
A running fan is always better than a stopped fan
Old Jul 7, 2011 | 09:03 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
Originally Posted by IDriveAnM5
Hey Guys,
Thanks!
Have owned 5 benzs in the last 5 years. all S550. the fan is very noisy. sounds like a diesil engine in the summer. but it cools the heck on the inside.
dont worry completely normal.
Old Jul 8, 2011 | 12:56 AM
fbracer's Avatar
I don't know if relevant but check this out (credit to Konigster):
P-B-07.61/71 JUL07 Check Engine light is illuminated and the radiator fan runs constantly this fault may occur when the engine is at operating temperature and is then switched off and restarted immediately. The temperature sensor will be checked with DAS. Note you should always wait longer than two seconds prior to restarting the vehicle.
Old Jul 8, 2011 | 08:19 PM
no engine light. the fan goes nuts when its really hot outside. right now we r at 100' + days of summer it is normal.
Old Jul 8, 2011 | 09:48 PM
famous550's Avatar
S550, 2006 Range Rover Sports Supercharged
Same goes for my S class and my friend's CL
Old Jul 9, 2011 | 10:16 AM
IDriveAnM5's Avatar
Figured as such thanks all. Just loud.
