Help!!! Can I use my stock bolts/lugs on my new rims?
Old Jul 20, 2011 | 07:12 AM
jadeethan's Avatar
toyota sienna, S550, Subaru Outback
hi members,
I got a set of aftermarket rims the euro26's. Can I still use my stock bolts with the new rims? I was intending on putting on my wheels tomorrow and would like to know asap!
Thanks in advance!
Old Jul 20, 2011 | 10:02 AM
Quadcammer's Avatar
96 and 08 911 turbos
I'm not sure anyone knows what the euro26s are.
Without look at the thickness of the bolt area, its pretty hard to tell.
When I went to aftermarket wheels, I needed longer lugbolts.
Old Jul 20, 2011 | 10:11 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
Check if your new wheels need a ball or cone seat. Then compare how far the lugbolt sticks out the back of each wheel to determine if you need a change for it to be longer or shorter.
Old Jul 20, 2011 | 02:53 PM
phatisfy's Avatar
S-class
You should be able to use your stock blots if anything. If you couldn't. I think the seller should of included you a set.
Old Jul 20, 2011 | 06:52 PM
jadeethan's Avatar
I found out that I need the conical ones...stock won't work! Thanks guys we can close this thread!
Old Jul 20, 2011 | 06:55 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
The post above about the seat is very important. Many of the aftermarket wheels have cone shaped seats. MB's tyically are ball shaped. If you mix and match the wheels are going to be unstable and not give you the proper fit.
