My conversion plus rims, lowered
Rims are 20 Amg replica 9.5 all around (wanted to go with 21' but couldnt
find replicas in that size)
Lowered with ghost links, is anyone else had problems with rear link loosen
by itself after driving for sometime which leads to raising car to insane suv level?
What is a roadforce balancing?
Thanks.
Nothing looks too extreme, just classy but different enough to turn heads.
21's can look a little ghetto if you don't choose the right design.....especially with chrome.
Your's are on the money.
I agree on adding spacers, as well. The rear height looks great, but the front could come down a little bit. Looks good overall. Try some loc-tite or similar thread locker on the lowering links.
The ride is so bumpy cause of the links if you use a real lowering module like the one from renntech you can hardly feel a difference...
They make thoose wheels in 9x22 replica's ive seen them on ebay a couple of times..
Other than that the car looks really good, cant wait to get the facelift frontbumper on aswell
Thanks but i ve seen 22s also, but i really think that this rim style is just perfect size in 21s.
HOw do the fogs work? Do they act as day time lights or just turn on when you want them to at night?
Can you share what did there..did you have to rewire was it plug and play?
Thanks'
1 Connect to them to fog lights and add resistor in between
2 Connect directly to ignition, so they will act like DRLs (WhiteOnWhite suggested this)
3 Rewire and connect it to the DRLs that are in the headlights. (Hardest method for me)
Personally i will connect them to foglights switch. My electric told me it will be the safest way, so if something goes wrong it wont mess up ur computer or smth, just a resistor.
How would you rate the difference with module versus the links?
Like if stock is 10/10 then with links and alignment done, for me is like 8/10
