Bluetooth Phone Issue
This feature no longer works. When entered at Call Lists, a popup shows, "Updating Data, Please Wait......" There's an "OK" tab, too. The net is it never updates. It just shows the clockface like circular indicator going around and around, but it never completes. I thought maybe I was too impatient, so I let it grind for five plus minutes...same activity as when started.
I can live w/o the convenience of who called/who I called history, but it is not updating new entries I add to my Samsung phone. That's the biggest downside. If I want to call someone I have entered in the past months, I have to manually use the phone.
I had the dlr. do a Command update nine months ago. I had the latest Nav cd data loaded some months ago
The net is could those have impacted the feature? As mentioned, the function worked at one time.
Any ideas on a fix? A fix w/o paying umpteen hundreds (out of warr./no extended) to the dlr. to screw it up more or screw something else up?
Again, not a mission critical function, but nice to have working.
Thanks.
Thanks.
After that, by any chance did you update your mobile recently?
If not, it could be the COMAND update if the problem started around the same time.
or you can just get the bluetooth cradle like this if your car is pre-wired
http://cgi.ebay.com/ebaymotors/Genui...item4aaec4f82e
then just program the phone / bluetooth and it will connect that way
