Easiest way to replace the parking bulbs?
Old Sep 29, 2011 | 08:25 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
what's the easiest way to get in there to replace the parking bulbs?
Old Sep 29, 2011 | 08:55 PM
phatisfy's Avatar
S-class
You need to turn the wheel all the way to L/R depending on where you start and remove the 2 plastic push screws, then just pull the wheel liner out. You'll see where the bulb socket then. If your hands are not small enough (tight space) use a long needle nose plier to twist it out.
