My W221 project..
Old 10-14-2012, 03:58 PM
  #501
ProjectCamaro's Avatar
Pewter W211
Welcome back Chris!
Originally Posted by BAPKC
Isint that what forums are for ?
You'd think...
Old 10-14-2012, 04:42 PM
  #502
jett3jett's Avatar
2021 G63, 2016 S550, 2019 RR 👻
Originally Posted by greekviking
"I was searching all over for this!! I want to get AMG on my cluster when i turn the car on along with the 200mph speedo. Chris Ive seen this done before from carlsson I'm sure your familiar with what I'm talking about since you know everything w221. Any ideas? "
Hey Chris,
Do you have the flash to change to the AMG speedo?
I believe you can do it with star DAS and rewrite software...any ideas.?
Thanks again, as always your knowledge is appreciated greatly.
BUMP
Old 10-15-2012, 02:41 AM
  #503
Chris The Swede's Avatar
W222 S63L, ML/GLE350
If I tell you my email I guess they see that as advertisement as well.
Old 10-15-2012, 02:42 AM
  #504
Originally Posted by jett3jett
BUMP
I have not seen anyone make this work so far.
Old 10-15-2012, 04:27 AM
  #505
BenzV12's Avatar
W212 FL
It should be OK to use Classifieds Forum not even this W221 to sell left over parts of your W221 but let's say if you sell other consumables , accessories then it's wise to say it's out of forum rules because you or anyone can knock out of vendors by this way .
For instance : I swapped my steering wheel and if I ever decided to sell it I should use Classifieds not even W212 Forum
Old 10-15-2012, 06:43 AM
  #506
rene_gts's Avatar
Just share your Skype/MSN, it's for communication And it really shouldn't be forums business about what you decide to talk there.
Old 10-15-2012, 10:02 AM
  #507
NickCats's Avatar
2018 E300 4MATIC Sedan
Absolutely beautiful car - great job !
Nick
Old 10-16-2012, 04:11 AM
  #508
Nick
Thanx a million...
Old 10-25-2012, 09:39 PM
  #509
jett3jett's Avatar
FINALLY got all the interior flooring in black. Took a long time to get. Was darkgrey before. Dont go so well with the new interior collors.
I want this so badly! . How much did this run you? Hopefully you can point me in the right direction
Old 10-25-2012, 10:00 PM
  #510
SL4Life's Avatar
On my 3rd coupe!
Jett there is a upohlstery spray paint that works really well. You'll also save yourself some $$$
Old 10-25-2012, 10:39 PM
  #511
jett3jett's Avatar
Interesting, do you know the name off hand?
I don't want to cheap out and do a half-assed job but if it works well i would certainly consider switching to black carpet. My seats are more of a butterscotch than tan and i think it would blend nicely
Old 10-25-2012, 10:46 PM
  #512
SL4Life's Avatar
On my 3rd coupe!
http://www.sprayitnew.com/collections/simply-spray-upholstery-fabric-paint
Old 10-25-2012, 10:47 PM
  #513
SL4Life's Avatar
On my 3rd coupe!
Also, check your local Pep Boys etc.
Good Luck.
Old 10-26-2012, 03:06 AM
  #514
I bought it new from MB.
Old 10-26-2012, 03:50 AM
  #515
jett3jett's Avatar
Thanks, ..PRICEY! $$
Old 10-26-2012, 05:49 AM
  #516
Yes..Very...
Old 12-11-2012, 10:28 AM
  #517
driftmeister's Avatar
CLK 240 V6
Hi Chris & Everyone in this thread...
After seeing your build and swapping up into something better, now I am so anxious to get a W221 2007-2009 spec. I am from Malaysia, currently have a W124, W126 & W209, while my DD is a 2012 VW Passat EURO spec.
Hope your SL65 project is coming up good....Cheers & Merry Christmas everyone!
Old 12-11-2012, 12:43 PM
  #518
Hope you get one...Please post it here on the forum when you start on it.
Old 12-12-2012, 06:52 PM
  #519
sanjaysingh's Avatar
2007 S550 & 2005 S500 (both FULLY loaded incl. AMG sport package)
Chris, you are THE TRUE GURU of modifications. The pictures and posts of yours are also TRULY UNMATCHED...They make things so easy for newbies and newcomers... HATS OFF SIR.
Old 12-13-2012, 02:49 AM
  #520
Thanx a million!!! That is why I do it...
Old 12-19-2012, 12:57 PM
  #521
Denys's Avatar
2008 s320 CDi limo
Hazard switch
Hi Chris
As you changed the interior do you have a diagram or pictures of how to remove the centre console and remove the hazard switch
Old 12-19-2012, 04:37 PM
  #522
Should be in the thread...
Old 12-19-2012, 06:25 PM
  #523
SPONSOR
PelicanParts.com's Avatar
Car looks amazing!! Great work.
-Trinidad
Old 12-22-2012, 12:19 PM
  #524
Denys's Avatar
2008 s320 CDi limo
Centre console
Hi Chris
I can not find the pics explaining how to remove the console , please can you help
Old 12-23-2012, 03:35 AM
  #525
It is very simple. It is 2 screws under the front box and 2 screws in the rear bottom on the sides behind small caps. Then it just slides out backwards.
Quick Reply: My W221 project..
