Driver seat enter/exit option in COMMAND
Old Oct 7, 2011 | 10:45 AM
Em Bee Lover's Avatar
CL550 1976 450 SL
Through COMMAND and Vehicle tab, there's an option that automatically raises the steering wheel and moves the driver seat back to make exiting easier. Conversely, it moves the wheel down to a programmed position and moves the seat forward to a programmed position when entering. I love the option (I am 6'3" & 285 #'s).
Here's my ask---To get the option to work, I must have the seat forward quite far. My knees literally touch the bolster. Not the most comfortable. Can the thresholds be reprogrammed? That is, can the point in the seat travel be changed and the option still work? If I move the seat back to give me more room, push "M" and "1", the option doesn't work, as I must have moved the seat back beyond a software acceptable point. I move the seat forward to near knee-touching, push memory and one and voila', the option works.
Again, due to my size, I love the seat back for entry ease and moved back for an easier exit.
Any and all help appreciated.
Thanks.
PS-Dealer SA said they could not be changed. But, who hasn't found them not always right?
Old Oct 7, 2011 | 01:51 PM
Diesel Benz's Avatar
I was about to say: "this time the dealer was probably right" but I had a look at the seat version coding options and it does have several settings:
Change standard distance of travel
Change minimum distance of travel
Adjust end of forward range
Adjust beginning of rearward range
I believe it is the last one that you are after. You should see which setting is currently programmed, Star does not allow all values but settings in a specified range (to leave at least some space for rear passengers for safety reasons).
Old Oct 7, 2011 | 04:03 PM
CL550 1976 450 SL
DB, thanks for the very informed reply. I'll contact the SA and "suggest" there are programming flexibilities. If I get a run around, I'll have some ammo.
You are always there for us with tech questions. Speaking surely for myself, but likely for most on this site, please know your involvement and expertise are really helpful and appreciated.
Old Oct 13, 2011 | 07:07 AM
listerone's Avatar
2018 BMW 540d
Agreed.DieselBenz is an important,and much appreciated,asset to this site.
Old Aug 31, 2016 | 07:32 PM
Sammyg96's Avatar
CLS550
Ease of entry
2014 CLS550, have ENABLED, "ease of entry", but it does nothing... any suggestions ? thanks gn
Old Aug 31, 2016 | 10:03 PM
DaveW68's Avatar
Veteran: Army
2015 S550
That's likely because you have your driving position pretty far back. If you move your seat closer to the front of the car and set the memory that way, your auto exit feature should begin working.
Old Aug 31, 2016 | 10:06 PM
Sammyg96's Avatar
CLS550
i have the seat fairly close to the steering wheel..... so thats not the issue.... miust be doing something wrong... ty for the response
Old Sep 3, 2016 | 10:44 AM
sloanbj's Avatar
'72 Fleedwoot
You need to reset it. First try moving the seat all the way forward and back. If no luck,disconnect battery.
