Seatbelt beeping
Old Oct 15, 2011 | 12:16 AM
Reclining S550's Avatar
S550
Seatbelt beeping
Is there a way I can turn off the seatbelt sound with out useing the seat belt
Old Oct 15, 2011 | 12:24 AM
lboudreau's Avatar
2023 E53 AMG, 2024 EQE AMG SUV
More than likely doable in STAR... but I doubt a dealer would be willing to assist in doing it.
Old Oct 15, 2011 | 07:01 PM
ULJets's Avatar
07 S600, 09 ML63
I've read on another thread here that you can tell the dealer your instrument cluster "freezes" from time to time and that the dealer will (or should) then do a IC software update. Supposedly that update solves the seat belt ringing nuisance issue. I've been meaning to get this done for a few months now but haven't had a chance to yet...planning on trying it towards the end of the week. I'll let you guys know if it works or not.
Old Oct 16, 2011 | 04:03 AM
S550
yes please lmk after if it works cause it gets annoying thanks
Old Oct 16, 2011 | 12:03 PM
lboudreau's Avatar
Solve? Is it broken? As far as I'm aware the seat belt chime is a safety feature. I doubt an IC software update will remove it.
Old Oct 16, 2011 | 01:11 PM
Diesel Benz's Avatar
No it would not, at least if the SW update is done properly. In an odd case settings might change if the cluster is not SCN coded after the SW update (or manually coded for correct settings).
Old Oct 16, 2011 | 03:03 PM
ULJets's Avatar
07 S600, 09 ML63
I'm sorry I mixed up my warning messages/chimes. The one I was referring to is the "don't forget your key" message and accompanying chime whenever the drivers door is open. For some reason I thought that's what the OP was asking about since the seatbelt chime is a safety feature and not a nuisance as you pointed out.
Old Oct 17, 2011 | 11:45 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Reclining S550? The seatbelt must interfere with the gangsta lean. It's okay, one crash and game over.
Old Oct 17, 2011 | 05:48 PM
S550
Yes the "gangsta lean" because everybody that wants to turn the seatbelt sound off wants to "gangsta lean"
Old Oct 20, 2011 | 06:35 PM
NuMBS500er's Avatar
2014 E350 4matic sedan
I saw something on EBay may be what you want. It is a fiber carbon clip like the one you have on the seat belt. You just stick it in the locking mechanism and made the car think you have the belt on.
Old Apr 27, 2018 | 04:01 PM
reedickyaluss's Avatar
cls550
https://www.ebay.com/itm/262179650129
Old Apr 28, 2018 | 06:08 AM
becosemsaida's Avatar
E-200 CDI on steroids (W212)
Well since you are thinking about an inexpensive solution let me help you out then: just pass the seatbelt behind your seat and insert it........ And NO i will not send flowers !!!!!
Beco
