Subwoofer Blown
Old Nov 10, 2011 | 05:49 AM
745Japan's Avatar
745i BMW '05, S550 '08
Subwoofer Blown
My sub rattles like hell gents. Can someone provide a part number so I can purchase one in the USA for a decent price. Sounds terrible. From here on out, I guess I should turn it down a notch or so. Dang it. Thanks in advance. Would love to replace it with aftermarket amp and sub, just not sure its worth the trouble.
Old Nov 10, 2011 | 02:28 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
I have one.....Let me know!
Old Nov 10, 2011 | 05:04 PM
745Japan's Avatar
How much are you asking? Also can I DIY this, what is required to replace the sub in the S550?
Old Nov 14, 2011 | 06:29 PM
silkz03's Avatar
s550
Hey, I'm having the same issue, sub rattling. I'm in need of one too. If anybody else has one for sale for an 07, let me know...ready to buy. I'm in San Antonio.
Old Nov 15, 2011 | 01:55 PM
C-DiZzY's Avatar
2010 S550
I cant tell where my rattle is coming from.. But i think I blew mine too. Anyone get a price yet?
Old Nov 15, 2011 | 01:57 PM
djrabbi's Avatar
I have one.....$300. I am in NJ also so you can pick it up... it is $1000 at the dealer.
Old Nov 15, 2011 | 01:58 PM
C-DiZzY's Avatar
2010 S550
Where in Jersey?
Old Nov 15, 2011 | 01:59 PM
djrabbi's Avatar
Clifton
Old Nov 15, 2011 | 02:01 PM
C-DiZzY's Avatar
2010 S550
Im in Garfield.. Have you replaced yours already? Is it easy to do?
Old Nov 15, 2011 | 02:02 PM
djrabbi's Avatar
No I haven't which is why I am selling it haha...S550 was traded in for CL600
Old Nov 15, 2011 | 02:03 PM
C-DiZzY's Avatar
2010 S550
Let me know when you can meet me.. I'll take a look at it
Old Nov 15, 2011 | 02:09 PM
djrabbi's Avatar
Don't matter to me. Come by whenever you want... PM me
Old Nov 15, 2011 | 03:34 PM
silkz03's Avatar
s550
PM'd you.
Old Feb 17, 2014 | 06:00 PM
Rdgreen88's Avatar
S430
easy fix... Just pop off the big black cover behind the headrests with a flathead and glue the subwoofer back to its plastic backing with some elmers or gorilla glue... took 5 minutes...
Old Feb 17, 2014 | 06:04 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Wouldn't that limit the travel of the sub?
Old Feb 17, 2014 | 06:37 PM
Rdgreen88's Avatar
S430
Not at all its not the speaker your glueing... Its the plastic holding at the top you will see what i'm talking about... Play some loud bass and use your finger to suppress the rattle.. then just squeeze a little glue and let it dry and you will be on your way.. Trust me I listen to rap and It's sounding official!
Old Feb 17, 2014 | 06:46 PM
azizblue's Avatar
2011 s63 amg
mines was done under warrenty
Old Feb 18, 2014 | 01:24 AM
Jason B's Avatar
Is this what you mean? Some good detailed info here and pics of the procedure.
http://www.benzworld.org/forums/w221...epair-fyi.html
I actually had different problem. The metal basket under the sub was super rattling and you could hear it from in the cabin on hard bass notes. I wedged in some rubber washers under the sub and it's fixed. To test if this is your issue, push up on that metal piece with the holes in the trunk. If it goes away when pushing on it, put some rubber washers in there. They don't touch the sub, it's just to add some width to stop rattling.
Old Feb 20, 2014 | 06:28 PM
Jason B's Avatar
Close-ups pics of the w221 sub and rear deck speakers you didn't know you had
Old Feb 21, 2014 | 10:17 AM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Jason..good pics, thanx
Hd
Old Sep 22, 2019 | 11:00 PM
S550Stuntin's Avatar
2012 Mercedes S550
Subwoofer rattle
Hey Jason where did you get the washers from what are the size of them? I’m having the same issue the speaker under the panel is not loose from the plastic like in that other thread that was mentioned. It’s more like yours where the metal cage of the sub woofer is touching so it’s really loud and rattles with high bass. Just looking to get the same washers you have to see if it helps with my issue. Thanks!
Old May 18, 2026 | 12:57 AM
nys29's Avatar
2015 S63 Coupe, W221 2010 S300
I have the same exact issue here. If I push the cage up with my palm, the rattle on high bass goes away. Where exactly do I put the washers and what type of washers should I get? I was thinking of using automotive sound deadening material and pasting some on the cage to see if it works. But maybe the washers method might be a better fix?
Old May 18, 2026 | 06:36 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
I don't have an answer for you, but your question reminded me that I'm having crackling in my right rear speaker--the one that's part of the subwoofer unit. Any ideas for fixing that, other than my current solution of fading the volume all the way to the front?
