problem with LED tail lights
Old Nov 25, 2011 | 12:27 AM
titanle's Avatar
BMW X6 Activehybrid
Exclamation problem with LED tail lights
So i just installed the 2010 facelifted LED tails on my car and i have run into a problem. When I unlock with the remote, on the drivers side the orange signal portion flashes and on the passenger side the entire red portion lights up. I only found 1 plug on the back so i dont know why this would happen.
can someone please help me out
thanks
Old Nov 25, 2011 | 01:00 AM
titanle's Avatar
BMW X6 Activehybrid
i tried unplugging the connector a few times on the driver side and when i would arm the car, the red lights would flash just for a moment and then back to just the bottom signal light flashing.
on the passenger side only the red leds flash during arming not the amber ones
Old Nov 25, 2011 | 01:09 AM
JonMBZ's Avatar
06 C55, 09 E350
That's not the only problem you have, you just haven't noticed the rest. I suggest you search this forum for more information.
Old Nov 25, 2011 | 01:12 AM
titanle's Avatar
BMW X6 Activehybrid
I've been reading the threads on this subject but i dont see what other issues may arise? It seems that everyone who has the new "plug and play" lights hasnt had any problems.
Old Nov 25, 2011 | 02:43 AM
titanle's Avatar
BMW X6 Activehybrid
so i left the car on for about 20 minutes but no changes in the lights. i disconnected both a few times and then the driver side began working properly and the passenger side had only the signal working.
very odd, im going to call mb tomorrow see if they can do a re-flash for me.
Old Jan 6, 2012 | 12:01 PM
malahhaor's Avatar
06 Carrera4
Any updates?
My right light is loosing a couple of LEDs and i think i might just get a set like yours. Hope not to run in to the same issue.
Old Jan 9, 2012 | 09:17 AM
brownbomber's Avatar
2008 S550 AMG
Where did you get your tail light upgrades from, and are you able to return them? Fishcake was recommended on several threads and I need to know moving forward if this is an isolated event or a recurring one.
Old Jan 28, 2012 | 02:51 AM
titanle's Avatar
BMW X6 Activehybrid
Originally Posted by malahhaor
Any updates?
i messed around with the wires a bit, made sure everything was plugged in firmly. I noticed that in the plug located in the tail light, the connectors werent sticking out evenly. i pulled the contacts out a bit and then everything started working fine. It was something to do with the plug thats locatd in the the tail light itself.
ive had them for about a month or so now and they are working great.
Old Jan 28, 2012 | 02:53 AM
titanle's Avatar
BMW X6 Activehybrid
i got mine from fishcakes after reading the threads. i think this was an isolated incident. everything was wired correctly but the problem seems to lie within the plug thats connected to the tail light. The connectors werent seated properly so i fiddled with them a bit. and after that they worked good. I did contact fishcakes about the problem and he said i would need to ship the lights back and after inspection they would determine whether a replacement would be sent. i didnt want to deal with the hassle so i ended up messing with them until i got them to work.
Old Aug 3, 2012 | 11:24 PM
kblair3d's Avatar
2014 GL 450
whatever happen here? how did they hold up
Old Aug 4, 2012 | 12:09 AM
Dr Feltersnatch's Avatar
amg cl/s
i had two from fishcakes that did that. they are erroring, get a replacement. he sent me a used defective one to replace my defective one. lol. good luck, it's broken.
Old Aug 4, 2012 | 02:06 AM
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
I got mine from fishcake too had a problem with them, he sent me resistor kit thats plug and play, 6 month later all led rows except in top corners went out, i resoldered everything with new wires, yesterday went out again. I noticed that ebay seller "expresspart" has them too but the connectors are diferent, anyone bought it from him before???
Old Aug 4, 2012 | 07:47 AM
kblair3d's Avatar
2014 GL 450
Will OEMs create error codes or work better? For the extra heartache t may be best if igomthatbroutentonsafe myself the agrivation is possible
Old Aug 4, 2012 | 11:58 AM
S_G7's Avatar
2007 S550V4
I would order the facelift tail lights from expresspart on eBay. Mine work flawlessly, no errors whatsoever. I bought them off the recommendation of others in this forum, particularly in this thread: https://mbworld.org/forums/new-s-cla...hers-s550.html.
I avoided fishcake due to all the problems reported with their tail lights in earlier threads.
Old Aug 4, 2012 | 12:00 PM
S_G7's Avatar
2007 S550V4
Yes, I bought mine from expresspart. Simple plug n' play and no errors.
Old Aug 4, 2012 | 08:11 PM
kblair3d's Avatar
2014 GL 450
thanks for the feedback, I'm reaching out now and hope to have them on by the end of the week
I was just contemplating the black or clear look there are two styles Im not talking about the smoked ones entirely ... One has the black lines instead of clear thats all I wish there were pics of them on so I can see what it looks like on a black car
Old Aug 5, 2012 | 12:53 AM
S_G7's Avatar
2007 S550V4
Glad to help. Chris the Swede has pics of the tail lights with the black lines on his black s550 here:
https://mbworld.org/forums/new-s-cla...roject-16.html.
Old Aug 5, 2012 | 07:59 AM
kblair3d's Avatar
2014 GL 450
They look hot but almost resembles a piece of electrical tape across the light. I think I'm going to go with the clear ones. He has done an incredibly impressive job on his car
Old Aug 14, 2012 | 01:00 PM
kblair3d's Avatar
2014 GL 450
I ordered mine from expresspart after reading the feedbacks and threads started, set to arrive on Thurs will go ON Thurs cant wait to change the look I cant stand the black bar on the '07's
Old Aug 14, 2012 | 04:55 PM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Dont look like tape in real life....Looks fantastic in my opinion...
Old Aug 15, 2012 | 09:02 PM
kblair3d's Avatar
2014 GL 450
It does and youre correct, didnt want to disrespect its all am matter of opinion. sorry
