Steering wheel chatter
Unfortunately it doesn't happen all the time.
Any suggestions are appreciated.
Kinda scary, plus this should not be happening in any car, much less a six figure one. Head mechs at two separate MB dlrs. felt it in the steering wheel and saw the wheels hop. Neither had seen this nor could say what was causing or what to check. Anyone had this? Thanks.
Is this what your's is doing?
I also posted this about that time.....After starting and putting in gear, if needing to turn left or right substantially or to where the steering wheel will no longer turn vs. simply going forward, there is a "chattering"/hopping in the front wheels as the steering wheel gets close to the end of its travel.
That is, the wheels/tires literally skip/hop/chatter. The skipping can be seen in the tire/wheel and felt in the steering wheel. This is on blacktop and cement. Haven't tried on dirt, grass or other surface.
This happens inconsistently. It happens as the steering wheel is getting to the end of its range of motion. Turn the wheel the full opposite and it again happens near the end of its travel. There is no skip/hop in the middle of the turn, just toward the end of its limit.It happens whether in park, neutral or gear. I cannot sense it happenning when vehicle is actually in motion or at speed. Plus, move the car but a few feet and turn the steering wheel from stop to stop and it often won't do it.
There is no "play" or sloppiness in the steering and the road feel is solid. Factory original 18" Continental "Conti" tires on stock wheels. Ex. MB dlr. head mech and now an indie has never seen and is lost for an answer.
I'd like to know if it is. I got no info via board, except one suggesting bushings. It's still doing it. Not gotten worse, just darn anoying. Thoughts?
Anyone familiar with steering rack or hydraulic valves or adjustments on these? Especially interested in 4matic advice?
Thanks!
