Howto replace-interiour-filter W221(Pics)
Old Apr 26, 2012 | 11:16 AM
marthyh's Avatar
S500
An easy job made easier with some pics:
get the filters either orignal or aftermarket; I got these ,you need two.
Remove 2x screws with T2.5 left and right: top footwell passengers-side and carefully move the panel.There is a light +wire attached to the panel.Undo the connector from the light.
Take the panel out.
This is the panel.
Then find underneath that panel: a ribbed cover with two slides: slide open, take the cover by pulling gently towards you:
Now you can see the filters,they will will probably fall out already.
Before you remove (I forgot)attention to the arrows on the filters its the airflow direction..
How the ribbed cover looks like.You can clearly see the 2 slides to open the thing.
The hole where the filters have to get back into.
The filters in place .
To re-install the cover and panel: work instructions in inverse direction.
Old Apr 26, 2012 | 11:27 AM
Atcpup's Avatar
S550
Nice Guide! Ty...
Old Apr 26, 2012 | 12:42 PM
brownbomber's Avatar
2008 S550 AMG
How long did this take, and what are those filters "supposed to do"? Very nice thread.
Old Apr 26, 2012 | 01:40 PM
new550's Avatar
2015 s550v4
Which direction is correct for airflow? Inside to out or outside to in on the filters? The two kind of make a "V" shape, but I also didn't look at arrows before removing old ones.
Thanks!
Old Apr 26, 2012 | 02:05 PM
marthyh's Avatar
S500
It took me about 40-60mins. alltogether,taking the pictures and figuring out what to do.
But should take no longer then 20 minutes if you are quick. I like to take my time thought and clean everything inside and out as well(some black dust inside the box and ducts)
The filters -filter the air coming from outside to in(also called pollen filters)so to breath clean air in the cab.
I have switched the blower on, to figure out the airflow direction and to my opinion I have directed both filters' arrows to the outside of the box towards the vent-holes into the cab.
Old Apr 26, 2012 | 07:31 PM
jadeethan's Avatar
toyota sienna, S550, Subaru Outback
How much do the filters cost if you don't mind me asking. Thanks
Old Apr 27, 2012 | 08:19 AM
marthyh's Avatar
S500
No worries, it was 21 Euro for the two I got, incl shipping .
Got them from ebay (Germany) ;see the label on the first pic.
But these filters are not the orignal ones.... the originals will be more.
Old Apr 27, 2012 | 11:05 AM
Em Bee Lover's Avatar
CL550 1976 450 SL
Filters PDF
Great job on thread. Simply offering info I posted Jan. 2011. I trust we are talking same filters. Mine is US 4Matic.
Attached may augment already solid instructions.
You can use eBay US to acquire fairly cost efficient filters.
WHEN ATTACHING MY PDF PICS IT TELLS ME IT'S ALREADY ATTACHED. I DON'T SEE IT. IF SOMEONE FEELS THE PICS FROM FILTER MAKER MANN WOULD BE OF VALUE, PM ME.
Old May 3, 2012 | 03:12 PM
Super Salami's Avatar
'08 Designo S550, R32 Nissan Skyline
Great, thanks for taking the time to document and share this with us!
Old May 4, 2012 | 01:09 AM
marthyh's Avatar
S500
Very welcome everyone!
Hopefully I can inspire my fellow W221-owners to do the same for all sorts of installs and maintenance.
Especcially as this is a relatively complex vehicule ,its good to be able to get as much info(and pix)as we can..!
Old May 4, 2012 | 05:31 AM
BenzV12's Avatar
W212 FL
Good job , this forum needs FAQ for such handy topics because it will be far easier to track down how to tackle a job in these cars
Thanks for posting
Old Jun 25, 2022 | 02:44 PM
martyngb's Avatar
S Class 2013 350d
Thanks!
They should be pointed towards each other, I'm rather amazed at the bad advice on direction online. 🙂
