Airmatic issues. Front suspension won`t rise
The cars fron is sitting at the bottom of its height at both sides. The rear end functions fine. At first, we thougth the issue might be from the valveblock, so we changed this unit. The swap for a new unit did not help. We tried to undo the the airmatic hose from the struts, and no air is coming out of the hoses at either side.
There are no signs of leaks, and even with a leak, there would besom reaction / air coming from the hoses upon being disconnected.
There are no "Warning, car to low" mesages in the display.
What could cause this? As stated, both side are having the same issues. Could this be the height level sensors? I heard rumors that they interact, and that if one fail, the second side will still keep the height on both sides? Perhaps the second one has failed as well, letting the car sit on the ground thinking its level is fine due to the busted sensors? Thank you for any advice.
You should diagnose the car properly with Star before throwing parts (you can purchase your own tool at the cost of swapped parts that were good).
